Strange Timing issue
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Trying to set timing. At 6, 8, 10, 12 and the EST plugged back in it idles smooth but if i try to give it too much gas it will stumble and backfire if i dont let off. With the timing advance way out it will idle like crap with the EST plugged in which is expected but throttle responds and doesn't backfire/stumble. It would be great if i could take the throttle response and combine it with smooth idle.
The distributor is new and have checked firing order. TPS voltage is at .5 at idle and goes up past 4.5 at WOT. It is also much harder to start when the timing is set to where it should be. When it advanced it starts right up.
What could cause this? Plug wires checked out ok. Any other causes i should check out?
Turned out to be the plugs and wires. Changed em out and she runs beautifully again. Thanks Guys
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: Strange Timing issue
Try spinning the the distributer around 180 degrees and time it again.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I've seen smooth idles with dist 180 out before. I'd find TDC compression stroke, and make sure rotor points to #1 wire, then double check firing order again.
Car: 1987 Trans Am
Engine: 5.7 350 TPI
Could it possibly be a weak ignition coil? I used a screw driver and watched the spark jump from it to a bolt under the hood. The spark was a yellow color. Correct me if i'm wrong but it should be a nice bright blue spark.
Car: 1987 firebird formula
Engine: none
If its carbed I wouldint spin the dis. 180 I've done it and it just blew a cloud of smoke out the garb when I tried to start it, the intake/exhaust phases for the pistons will be opposite of the carb. If its fuel injected idk what will happen
theshackle
Sep 17, 2020 08:26 AM
red90IROCls1
Aug 25, 2015 06:56 AM
