Can the wiper switch be removed without removing the steering wheel?
Old Mar 19, 2011 | 08:57 AM
sharky55's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
I thought I read somewhere on the site here that the wiper switch in the steering column could be removed without having to remove the steering wheel. Is that possible? From what I understand, it is contained within that little housing on the steering column but I don't see a way to pop that off.
Old Mar 19, 2011 | 01:56 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: Can the wiper switch be removed without removing the steering wheel?
It is behind that cover, but the wheel does need to come off to change it, as well as the turn signal switch and that lock plate.
Old Mar 19, 2011 | 02:13 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes. Check the following link:
https://www.thirdgen.org/forums/body...h-removal.html
JamesC
Old Mar 20, 2011 | 08:45 AM
sharky55's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
That link actually just describes removing the multi-function lever. I was able to do that pretty easily. The problem I am having is with the wiper switch which is actually located at the base of that lever stem IN the steering column.
Old Mar 20, 2011 | 08:50 AM
JamesC's Avatar
If it's in the column, perhaps you'll find what you need here:
https://www.thirdgen.org/forums/susp...-steering.html
JamesC
Old Mar 20, 2011 | 09:33 AM
sharky55's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
Yes, that is a good link with good pics. Thanks James.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
