headgasket blew, cylinder had old water in it, need advice
Old Mar 19, 2011 | 03:24 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
just pulled the head off... the one that blew the gasket...
looks like there was some coolant sitting in there a little while.. has etched the cylinder wall... what are my options on cleaning this ? i already scrubbed the wall with a paper shop towel and carb cleaner to try and get some of if off... should i take a hone to it? i can turn the crank and get the piston to BDC on that cylinder and water marks about half way up the cylinder wall.
i really dont want to disassemble the short block
Old Mar 19, 2011 | 04:55 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
Re: headgasket blew, cylinder had old water in it, need advice
I would try this. First get the piston at bdc like you mentioned. Then I'd made sure the cylinder is clean and dry. Then take some masking tape and go around the top of the piston to the cylinder wall so nothing can fall down between them. Then I'd take a very fine scuffing pad( light gray scotchbrite) or 000 steel wool with a little 3 in 1 oil on it and clean it up. I'd go real lightly and see if that would do it. After you're done I'd wipe the bore clean with wd40 and some lint free shop towels to get all the grit out, then blow the cylinder out good with compressed air.
Old Mar 19, 2011 | 05:27 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
awesome, i'll try that 1st. thanks for the help, i will report back once tried.
Old Mar 19, 2011 | 05:43 PM
slayer2000's Avatar
Car: 1990 GTA
Something I didn't think about but you said this is ecthed. Do you mean it's stained for lack of a better word or has it actually piited the cylinder wall? If it's pitted I doubt this will do you much good.
Old Mar 20, 2011 | 05:55 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
no not pitting.. just a raised rusty patch
Old Mar 20, 2011 | 06:15 PM
Robby12's Avatar
how far apart is it id run a ball hone threw it
Old Mar 21, 2011 | 10:27 PM
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
well first i rememberd an oil trick for rust.. vinegar.. i got a shop towel, put some vinegar on it, and wiped the rust part to help break it ut. theni used 30wt oil and a mild scotch bright pad, worked it slowly and wow, worked like a charm, came off very easy.
thanks for the help guys
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
