valve spring??????
Old Mar 21, 2011 | 06:35 PM
chevymansmp790's Avatar
valve spring??????
i have an 84 trans am, i am building up a 350 it is bored over .060" i have ported and polished vortec heads 194/150 valve i am going to be running a comp cams thumpr 12-600-4 hydraulic flat tappet cam, i am looking for valve springs that i can use that require no machining of the heads, the cam has .479 intake and .465 Exhaust lift, anyone have any ideas???? i heard something about stock ls1 beehives? HELPPPPP
THANKS SHAWN
Old Mar 28, 2011 | 01:56 AM
1969RSSS's Avatar
Car: 69 Camaro,88 T/A,03 Prius
Transmission: M22
Axle/Gears: 12 bolt 3.73 posi
Re: valve spring??????
you can use ls6 beehives(less then 100 bucks but prone to breaking) with comp cams 787 retainers and locks, or comp cams 26915 or 26918(about 200 bucks) beehives and should be fine with your total lift.
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
