Wanting to remove AC and SMOG from 305, HELP!
Old Mar 25, 2011 | 12:42 PM
jsanders's Avatar
Car: 1992 25 Anniversary Chevy Camaro RS
Engine: TBI 305sb
Transmission: 700R-4
Axle/Gears: Stock
I have a bone stock 1992 Camaro RS with the 305. I'm wanting to remove both the AC and the smog system from this motor. My AC does not work, and I don't care for it to work because I wont be using it. And the smog system as we all know is worthless as well, just a parasitic setup that robs our already weak 305 motors. I read up on how to remove the smog system in the tech articles but I'm wondering what else has to be done when removing the AC compressor?? If anybody can help that would be amazing, pictures help as well haha.
Old Mar 25, 2011 | 01:45 PM
jsanders's Avatar
Engine: TBI 305sb
Axle/Gears: Stock
Re: Wanting to remove AC and SMOG from 305, HELP!
I'm guessing that I need an AC delete pulley so I can still use the tensioner huh? Hmm... Or is there a way to delete the AC and not use a delete pulley.
Old Mar 25, 2011 | 02:57 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Do you have emissions in your state? if so you might not want to remove your smog.
Old Mar 25, 2011 | 03:13 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You can remove one or the other without a delete pulley like you read, but you have to get a delete pulley to remove both. Napa sells for about $30 I think, get the A/C delete pulley then follow that tech article.
Old Mar 25, 2011 | 03:31 PM
jsanders's Avatar
Engine: TBI 305sb
Axle/Gears: Stock
Nope I don't have to worry about emissions thank god lol.
jsanders's Avatar
Engine: TBI 305sb
Axle/Gears: Stock
And I live in the one city in the entire state of MO without a NAPA. I wonder if other parts stores carry them...
Old Mar 26, 2011 | 06:42 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
First get your ac delete pulley, for the smog pump, you can remove all that trash, you will want to get a 968k6 belt to start, get it all set up, the route to re run this is a sticky on the main page this link will take u there https://www.thirdgen.org/serpentine, If you absolutly need pics, msg me as I just did this a few days ago.
Old Mar 26, 2011 | 07:48 PM
Car: 1992 RS
Engine: Carbed 350
The 968k6 translates to a belt with 6 ribs, that is 96.8 inches long - which is hard to find exactly - no one makes them but only in 1/2 inch increments anymore, so you'll have to test different belt sizes - I'd buy a 95, 95.5, 96, 96.5, 97 while I was at the store, and return the 4 you don't need. When I did mine think I needed a 95 inch, but everyone says you need a 96.8 inch
Old Mar 26, 2011 | 09:27 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Got my belt at autozone told them to give me 5 sizes and that direction, and thats the one that lined up the best!
Burnt.Clutch
Camaros Wanted
Aug 21, 2015 11:11 PM
jackhammer
Aug 15, 2015 10:04 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
