Engine woes
Old Mar 26, 2011 | 04:34 PM
exricer's Avatar
Engine woes
I really need to figure out what's wrong with my engine, but I have no idea where to start. I don't wanna get my head ripped off at a dealership and I don't know any reliable mechanics in my area, so I'm turning to you guys for some help
Engine:
87 LG4 V8.
Mods:
None that I know of.
Symptoms:
Burning oil - quite a bit. About a quart a week. No smoke, though.
Sputtering and hesitation - I noticed this the other week when going up the Cuestra grade by Pismo. I've been able to get it to do it a couple times since then. If the engine is under heavy load and below 2.5k RPM it hesitates. I don't mean slight. I mean, I honestly think it's going to shut off then it kicks back on and I can smell burnt oil.
Backfiring - only slight backfires when the engine is cold after lifting off the throttle. I really should leave for work sooner so I can let the engine warm up.
Sputtering and clunking - this is after the engine is turned off. And only occasionally. I can never guess when it'll do this and I can't reproduce it, so I can't even fathom what this might be.
Rough start - sometimes it takes about 20sec for the engine to start, but it doesn't die or anything once it catches. Only on a cold start, too, so I don't think this is a symptom.
That's about what I have going on. I was thinking oil leaking into the valve train, but I'm hoping it's not anything as severe as that. Thanks in advance for any help, guys.
Old Mar 26, 2011 | 04:43 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Engine woes
Check your plugs for oil deposits. Oil deposits will look like a white chaulky "flag" on the ground electrode. Check the PCV valve for being plugged, check the PCV make up air tube for restriction, check the PCV passages in the intake manifold for restriction.
As for the back fire and hesitation, check your plug wires for stiffness and signs of age. If plugs and wires appear old and tired, perform a major tune(plugs, wires, cap and rotor, PCV valve and hose, fuel filter, air filter).
Old Mar 27, 2011 | 07:27 PM
1969RSSS's Avatar
Car: 69 Camaro,88 T/A,03 Prius
Transmission: M22
Axle/Gears: 12 bolt 3.73 posi
Re: Engine woes
If you do find signs of oil fouling on the plugs and its not from a defective PVC valve or blocked breather system then you have either worn rings and or worn Cly walls or leaking intake valve seals or the cheapest problem would be a leaking intake gasket on the lifter valley side. If any of these are the case and you cant afford repairs you could install antifouling spark plug inserts. these do a decent job at slowing down the oil fouling but your plugs will still foul after some time.
Old Mar 28, 2011 | 01:32 PM
torque_is_good's Avatar
Re: Engine woes
to parrot what others say
absolutely plugs, wires, cap and rotor
after that, no more 87 octane. Stop using the stuff especially if you are going up grades
run at least 89
as for the oil consumption, inspecting your plugs will tell you and a compression test wouldn't hurt either
Old Mar 28, 2011 | 02:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Engine woes
Sputtering and clunking after being turned off is known as deiseling, sounds like a timing issue.
Old Mar 29, 2011 | 03:21 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Re: Engine woes
Deiseling can also be caused by heavy combustion chamber deposits.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
