Which Serpentine Belt to Use?
Old Mar 27, 2011 | 02:20 PM
musclecar274's Avatar
I have a 1988 Camaro with a 5.7 engine and the serpentine belt is starting to crack. How much longer should I expect the belt to last? Also, I was looking online to buy a new belt, but all the ones I see either say "Belt Does Not Run Directly From Crank To Air Pump" or "Belt Does Not Run Directly From Crank To Power Steering". Does this mean the Serpentine belts aren't long enough for this car? What belt should I be looking to buy? Links will be appreciated, if it is allowed per board rules. Thank you for the help.
Old Mar 27, 2011 | 02:59 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Which Serpentine Belt to Use?
You can take your belt to any auto part store and they should be able to grab a replacement off the shelf. Shouldnt be more than $30.
jrdturbo
Mar 31, 2016 02:58 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
