not sure what to text for, 305 tpi shuts off close to idle
Old Mar 29, 2011 | 05:13 PM
peicheff's Avatar
Car: camaro iroc-z
Engine: 305 tpi
Transmission: 5 speed
been doing this ever since i redid the intake manifold gasket, when the rpm gets relatively close to idle it wants to die, however when you start the car it has no problem just idling and minding its own business. any suggestions? iac? tps?
Old Mar 29, 2011 | 05:14 PM
peicheff's Avatar
Car: camaro iroc-z
Engine: 305 tpi
Re: not sure what to text for, 305 tpi shuts off close to idle
meant for it to say test in the title
Old Mar 30, 2011 | 04:22 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Get a vacuum gauge and check the intake vacuum. You may have a leak. Did you connect all your vacuum hoses?
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
