best oil pan options
Old Mar 29, 2011 | 10:41 PM
j_camaro_67's Avatar
Car: dark hunter red 84 camaro
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
i have pulled motor out to machine pistons for my head swap and figured i should swap to a better oil pan for better oiling while it was out, right now i have a steel 7qt oil pan with no baffles or any thing, what is the best oil pan for street/ strip, would it be worth putting a crank scraper in there as well, what do you guys think, thanks jason
Old Jan 16, 2012 | 02:43 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
Re: best oil pan options
I am Fixing to put my engine together and would llike to know that same
BUMP
Old Jan 16, 2012 | 04:43 AM
peterc005's Avatar
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
My stock L98 350 oil pan is damaged and I'd also be interested in suggestions.
Maybe an improvement over the stock pressed metal one?
Old Jan 16, 2012 | 06:12 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I'm running a moroso 6-qt oil pan with no issues. Had to modify my y-pipe a bit though as the bottom of the pan is larger, so the factory y-pipe won't go around it. Also have a high-volume melling oil pump in the car that came with it. You can check out summit, they sell them for about $150ish for the set (Pan + pump)
Old Jan 16, 2012 | 07:41 PM
rongreen's Avatar
Car: 1938 Chevy 2 dr Sedan
Engine: Dart400 AFR190 TPIS ZZ409 Big Mouth
Transmission: Gearstar 700R4 level 4
Axle/Gears: Moser 12bolt-Det Trac loc 3:42
I am using a TPIS 5 quart pan that is great it has a crank scraper and a windage tray. Give them a call...
Hotrodboba400
Dec 10, 2019 07:07 PM
carattini
Sep 10, 2015 07:46 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
