Need help drilling ARP bolt
Old Mar 30, 2011 | 09:02 PM
0pyders's Avatar
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
The bolt for the valve cover snapped off, does anyone know a good drillbit that can pierce ARP bolts? I tried using a cobalt bit with no luck.
Old Mar 31, 2011 | 11:20 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Need help drilling ARP bolt
You may be able to use a small punch and a hammer to slowly rotate the bolt. I did this once on a cam bolt i broke off.
Hope this helps.
Old Mar 31, 2011 | 11:28 AM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
or a left handed drill bit(drills in reverse) as it starts to drill into the bolt it catches and screws the bolt out
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
