injectors size to big???
Old Mar 30, 2011 | 09:34 PM
ENRIQUE125CC's Avatar
Car: 94 s-10
Engine: 355tpi
Transmission: th400
Axle/Gears: 5.38
Hey guy im new to this site i have a 91 tpi in a s-10 im having trouble keep it to idle break down on engine:
flat top pistons
stock heads 1.94 1.50 stainless one peice neck down valves
comp 1.5 ratio rockers
8 into 1 header 1 5/8 tube
injectors 30lbs
comp cam specs : intake .462 exhaust .469
duration @ .006 intake 262 exhaust 270
int open---25 btdc--- close 57 abdc
exh open---69 bbdc--- closed 21 atdc
tpi is all stock
tps is @ .53 idle 4.43 open
iac is free and clear and moves
fuel pressure 45
computer has been tuned
can you over do injectors so big that you cant turn the injector lenth down enough to tune thanks guys for your help
Old Mar 31, 2011 | 08:35 AM
JustCruzin's Avatar
Re: injectors size to big???
Yes
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
gixxer92
Sep 1, 2015 04:32 PM
knight72
Aug 10, 2015 09:32 PM
