Valve cover gaskets..
Old Apr 2, 2011 | 06:17 PM
Guest
Guest
Posts: n/a
So good day of taking stuff apart... next thing is changing the valve cover gaskets.. not done this a lot any walk through,threads or how to's? Thanks in advance
Old Apr 2, 2011 | 07:34 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: Valve cover gaskets..
what kind of engine (carb/throttle body or tpi)
also does your car have a/c, and if you still have all the emissions stuff its probably going to be a little complicated.
my advice would be to pick up a haynes manuel or something similar from an auto
parts store
id walk you through it but i removed my snorkle, and all the emmissions tubes and hardware when i put on my headers. that was a long time before cracked open my valve covers.
the bottom line is this... its not a difficult job to replace the gaskests. 4 bolts on each valve cover and your done. the difficult part is getting the stuff out of the way so you can remove them comfortably
Old Apr 2, 2011 | 08:31 PM
Guest
Guest
Posts: n/a
1988 2.7 FI yes it has the AC and all the emissions stuff is on there because I am in NY and it has to be :-( I got a haynes manual guess it's in there? Guess I will read scan though it.. Thanks for the help.. any other tips?
Old Apr 2, 2011 | 11:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Tip: Start calling it a 2.8 motor, not a 2.7 - there is no 2.7 motor.
Old Apr 3, 2011 | 08:49 AM
Guest
Guest
Posts: n/a
Ahh it is a 2.8 could of sworn it said 2.7 in the haynes manual... Thanks
Old Apr 8, 2011 | 08:08 AM
Twentyone's Avatar
Car: 84 Z28 HO & 63 425hp 409 Chev Impla
Engine: 305 HO
Axle/Gears: 3:73
Took me 5 hours to get cover off easy side(drivers side) on 84 Z28-RTV d gasket to cover and let setup overnight.It will probably take another 2 hours to get back together Had to just about pull air compressor to get cover out-The passenger side is much harder-any suggestions except for pulling engine-What a mess!!!
Old Apr 8, 2011 | 02:28 PM
Twentyone's Avatar
Engine: 305 HO
Axle/Gears: 3:73
Hey TNT Z28
Whats your advice as far as removing all the smogger crap-I still need to do other valve cover gasket-Maybe I`d be better off to just toss the Smogger crap at same time-Looks like I`ll have to remove most of the stuff anyway--What has to be done to keep engine in syncro with computer when removing all that stuff-
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
