WTF?? codes 22,33,36 & 45 AAARGGG
Old Apr 4, 2011 | 03:13 PM
tarrheel49's Avatar
OK so I'm a little STRESSED. I bought my 1987 GTA in December of 2009, It ran great for about a year. I was running an errand & all of a sudden the car just loses power & starts to over heat.(broken heater hose,fixed) I take the car out the next week and my check engine light is on. I get a code 22. So I check my POS Haynes manual and see it probably is TPS sensor...Replaced. I could only get voltage to .46. I've tried everything I know & followed suggestions from posts on this site. So this is what has been replaced:
Vacuum hoses(vacuum is solid at 17)
TPS sensor(pigtail also)
IAC valve(pigtail also)
now as of today my idle is at 1800 RPM & I got codes 22,33,36 & 45. Any suggestions? Thanks for looking.
Old Apr 4, 2011 | 06:30 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: WTF?? codes 22,33,36 & 45 AAARGGG
Unplug your MAF sensor. Post what happens.
Old Apr 5, 2011 | 10:27 AM
tarrheel49's Avatar
When I unplug MAF sensor RPM's go down. It revs & runs better in Idle. I've tried tapping on MAF sensor & have not noticed any change in RPM's, only when I disconnect it does the car seem to run better. I have tried to drive it this way, only up & down the driveway(100 yards) & car starts to stall & backfire.
Old Apr 5, 2011 | 08:27 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Looks like you've got a bad MAF sensor. You might want to shoot a pm to ASE Doc or camaronewbie and see what they think. Nothing wrong with a second or third opinion.
Old Apr 6, 2011 | 07:06 AM
tarrheel49's Avatar
Thanks for your help......
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
