Fuel Pump Relay Connector
Old Apr 4, 2011 | 03:18 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
can anyone tell me where to purchase a replacement fuel pump relay connector OR just the gm pack-con connectors that go inside of the connector.... I need this asap please.....
Here is a pic of the connector harness... you can kinda see the metal clips inside of it, which is what I really need.....
Old Apr 4, 2011 | 03:22 PM
74Novaguy's Avatar
Car: 88 Camaro IROC-Z
Engine: 5.7L 350 TPI
Axle/Gears: Stock
Re: Fuel Pump Relay Connector
AC relay - your picture is a AC relay connector
http://www.napaonline.com/Search/Det...+50012+2012008
Fuel Pump Relay connector
Or try a junk yard. may be cheaper
Old Apr 4, 2011 | 03:26 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
private message me your address, I can send you one, I believe I know where one is in my garage.
Old Apr 4, 2011 | 03:36 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
The link provided, gives me a picture of the later oval style connector. I am trying to find this connector or the metal inner clips locally if possible, If all else fails I will get with you regarding your part in N.Y.
Old Apr 4, 2011 | 03:49 PM
74Novaguy's Avatar
Axle/Gears: Stock
Look at the first like for ac connector. napa has it listed as an ac relay connector
Old Apr 4, 2011 | 05:14 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Thats it.... I will call my local napa and see if they carry it.... if not perhaps it will cross to oreillys or autozone...
Old Apr 4, 2011 | 05:36 PM
coryprine's Avatar
Car: 85 Camaro Z28
Engine: 5.7 TPI
Napa had it on hand, thank you very very much for the assistance.
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
