91 Firebird wont start
Old Apr 6, 2011 | 05:24 PM
arnold23's Avatar
I have went to look at a 91 firebird 5.0. The car had been slightly wreck. It rear ended another car just enough to set the airbag off and now it will not start. It does not crank over. What is the reason behind this? Any info will be appreciated
Old Apr 6, 2011 | 06:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 91 Firebird wont start
Does the starter turn?
Did you pull codes from computer?
Could be a gazillion things, We need way more info on what exactly it's doing or not doing.
Old Apr 6, 2011 | 07:37 PM
arnold23's Avatar
The electric fan, dash lights,and interior light all come on so there is power there. But when you turn the key nothing. Does not crank click or anything. Fuel pump also turns on you can hear the slight whir. The security light on the dash is also blinking.
Old Apr 6, 2011 | 07:45 PM
Car: 1992 RS
Engine: Carbed 350
It's a VATS issue then - you need to bypass the VATS module.
https://www.thirdgen.org/vats_passkey_system
Old Apr 7, 2011 | 05:33 AM
arnold23's Avatar
Ok Thank you very much for you help. Ill get back at you and let you know if it works.But thanks for your time.
Old Apr 7, 2011 | 05:57 AM
arnold23's Avatar
Also i have an 85 t/a its rusted badly but the fenders and hood are good. Would the fenders from the 85 fit on the wrecked 91?
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
firebirdchick28
Mid-West Region
Aug 16, 2015 02:52 PM
