easy way to remove thermostat..
Old Apr 8, 2011 | 04:41 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
i haev an 86 iroc 305 TPI, and was curious as if there was a way to just unbolt the 2 housing bolts to remove it, instead of taking the plenum apart. im running a 195 in there and not having good luck so i was planning on going with a 180, just curious as if there were ways to get it out easilly. last time i did was when we did the heads and replaced the top half, so that wasnt an issue
Old Apr 8, 2011 | 05:13 AM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: easy way to remove thermostat..
I'll admit I'm not familiar with TPI relevant spacing, but could you just remove the TB to give you enough clearance?
I don't claim to be a doctor, but I did stay at a Holiday Inn Express last week .
Old Apr 8, 2011 | 05:52 AM
jeff_blake's Avatar
ya have to remove throttle body to get to it. fun.
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
TheExaminer
Sep 6, 2015 11:40 PM
mantaguy
Sep 2, 2015 10:42 PM
RyanJB
Sep 2, 2015 01:27 PM
z28guy134
Sep 1, 2015 11:50 PM
