nasty plume of smoke?
Old Apr 13, 2011 | 10:56 AM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
it has a cam head work and cat delete.
i noticed if my car idles for more than a few minutes then you get on it you get a plume grayish black of smoke out the back is this normal
And at ilde you get a little puff puff of blueish smoke witch i wrote of as just gas in the oil from long periods of idle during tuning does that sound like something normal with the cam and idle time?
Old Apr 13, 2011 | 11:52 AM
sonjaab's Avatar
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Re: nasty plume of smoke?
Sounds like bad valve guides, bad valve stem seals or you may get lucky and
have a bad PVC valve !
Spend $5 bucks and try a new PVC valve first!
Old Apr 13, 2011 | 01:32 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
The black smoke you described sounds like it's running too rich. Does it blow blue smoke after it is warmed up?
Old Apr 13, 2011 | 07:06 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
is there smoke present at cold idle or at cold start up?
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
