View Poll Results: Too noisy
YES! Something is majorly wrong.
0%
Yes, but it should quiet down in a few hundred miles
50.00%
No, this is normal for this type of rockers and no valve covers
50.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Is my valvetrain too noisy?
Old Apr 13, 2011 | 10:03 PM
88gunmetalgta's Avatar
http://www.youtube.com/watch?v=2dCYthLKMXk
There's a video of my new engine.
Its a 383 with Comp Cams factory replacement roller lifters, and factory GM spider and dogbones, Comp Magnum pushrods, and Comp Ultra Magnum 1.6 ratio rockers.
I've adjusted the valves after the first start, adjusting one rocker at a time every 45* of crank rotation. I snugged up the locknut, then gave it an extra 1/4 turn.
The engine has less than 30 minutes of runtime, and hasn't been driven at all.
I don't know if this amount of valvetrain noise is normal for the combination of parts I have. I know full roller rockers are supposed to make more noise than stamped ones, but this still seems excessive. What do you guys think?
Old Apr 13, 2011 | 10:34 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: Is my valvetrain too noisy?
Sounds about right to me- I couldn't tell if they were roller tip, or full roller, but it sounds about similar to mine under the same conditions. Lots of ticking.
Mine's hyraulic flat tappet w/ 1.6 aluminum rollers.
Old Apr 13, 2011 | 10:57 PM
Thanks! This is my first experience with a high performance motor. I don't know what sounds are "normal"
And yes, they are Full Rollers
Old Apr 14, 2011 | 04:46 PM
Ok, I readjusted my valves again. My comp literature says preload should be a full turn instead of 1/4 turn.
I noticed that two lifters were easy to push down. they both seemed to pump back up a little bit during my valve adjustments, and then after running for a minute or so, I checked again, and one of them is still kinda spongy, but had gotten firmer with running.
Is it normal for a couple lifters lose their "prime" when turning the motor over slowly like I was doing during adjustment?
Zell1luk
Sep 29, 2015 10:36 AM
BLK87Z
Sep 18, 2015 11:29 PM
dimented24x7
Sep 6, 2015 03:51 PM
86White_T/A305
Aug 17, 2015 12:16 AM
johns84bird
Oct 17, 2001 07:58 PM
