Is the PCV valve suppose to pull out super easy, or is it wrong size???
Old Apr 14, 2011 | 04:41 PM
nakota2k's Avatar
Car: 1989 Iroc-Z 350
Been having some idle problems but not too bad. So that hose that goes from the intake manifold to my right head into the PCV valve. Barely tugged on it and the PCV valve just pulls right out of the head very easily. Is that normal?
Old Apr 14, 2011 | 05:01 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: Is the PCV valve suppose to pull out super easy, or is it wrong size???
shouldnt be a problem. you could replace the gromet if it eases your mind
Old Apr 14, 2011 | 06:05 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
They all do that.
Old Apr 14, 2011 | 08:41 PM
Yup; kinds depends onyour definition of "super easy". It shouldn't fall out if you pick up the motor and turn it upside down, but it shouldn't resist a pull either.
1992 Trans Am
May 10, 2023 07:19 PM
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
MENINBLK
Aug 5, 2015 11:58 PM
