91 B4C wont run when warm
Old Apr 14, 2011 | 11:41 PM
tjklrace's Avatar
When our 91 b4c Camaro gets warm it won't run at all. We've tried changing the computer, but it does the same thing. Tried wiring the fan to a switch and turned it on before it got very warm (several times) and it still won't run. Any ideas?
Old Apr 15, 2011 | 02:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 91 B4C wont run when warm
Maybe a new coolant temp sensor? 2 wire sensor located in the intake by the thermostat.
Old Apr 15, 2011 | 03:04 PM
ATOMIC's Avatar
Car: 88 gta (black/black wheels)
Engine: 350tpi
Transmission: 700r
Axle/Gears: 3.27 posi
good choice.
when the coolant temp sensor goes bad it shows negative degrees temp, something like -40f.
unhooking the sensor will show the same -40, it must be replaced to test unless you have a pc based scanner.
its only 35 dollars and they go bad VERY often.
make sure the parts counter doesn't give you the one for the gauge.
usually signs of this are stumble thru the entire rpm range, sometimes clearing at higher rpm, and massive power loss that gets worse as temps rise.
no restart when hot is also common.
often mis-diagnosed as ignition problems.
let us know if that's it
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
mustangman65_79
Aug 8, 2015 12:07 PM
