Installing oil pump
Old Apr 15, 2011 | 04:37 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Installing oil pump
When I install the oil pump to my engine with a stud and a nut instead of a bolt what torque value should I use when I tighten the stud? The same 65 ft-lbs that is required on the bolt or something else?
Old Apr 15, 2011 | 04:45 AM
Twin_Turbo's Avatar
Re: Installing oil pump
Stud goes in hand tight, tighten nut to stock specs
Old Apr 15, 2011 | 04:49 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
You mean I have to tighten the stud only with hand? Is this enough to keep it in place?
Old Apr 15, 2011 | 04:53 AM
Twin_Turbo's Avatar
Yes, make sure it goes in all the way so clean the threads and blow it out w/ compressed air.
The stud only has to engage all the threads, this gives you the retention contact area , which is a lot greater than the bolt has and it spreads the load over all the threads instead of the first couple, deforming them. There's no sense in tightening the stud, loading the casting and deforming it. That's the beauty of studs, full thread engageent and reduced deformation.
Old Apr 15, 2011 | 04:56 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Thanks for the detailed explanation, I will do it this way.
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
