computer distributor swap help
Car: 86 Firebird LG4
Axle/Gears: 3.23 limited slip
hey, If I bought something like this: http://www.summitracing.com/parts/DUI-12600RD/?rtype=10
could I just take out the 4 wire pin on my old one and hook it up to this? I can't find a distributor that has the 4 pins on it.
Car: 88 Camaro IROC-Z
Engine: 5.7L 350 TPI
Axle/Gears: Stock
Re: computer distributor swap help
what set up do you have TPI or TBI?
http://www.summitracing.com/parts/PRO-66939BK/
heres the one I just ordered for the TPI set up. I think the TBI uses the same one. Not sure on that one though
Axle/Gears: Stock
I think that davis 12600 you listed first is the correct one for your application. if you look at davis's website they show the harness on it
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
That is just the std HEI wiring from base to cap.
Computer controlled HEI dist has a seperate 4 wire harness and plug from the base to connect to the computer
Does the same function as the 4 wire connector in the small cap dist you bought
I think this is what nova was talking about: http://www.performancedistributors.c...mputerdist.htm
