Valve springs
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Valve springs
I have a:
88 formula 350
Ported 083 heads
Ported Base
Ported pleneum
Slp runners
I wanted to run a lt4 hot cam, but the springs that come with the kit wont fit the heads. I need a set of valve springs that will fit the heads without machine work.
I returned the cam and springs now Im looking for a alternative. Im kinda leaning towards the compucam 2032, but jegs still says there are no springs for it.
Please reccommend a springs and cam that will fit with no machine work.
Thanks,
Dustin
88 formula 350
Ported 083 heads
Ported Base
Ported pleneum
Slp runners
Thanks,
Dustin
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Valve springs
Manley has some that will work....PM me tomorrow and I will get you the numbers.
