In tank pump
Old Apr 24, 2011 | 05:28 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
In tank pump
If one was to do away with the computer in a 1987 Trans Am, will the intake pump still function as needed?
Old Apr 24, 2011 | 06:10 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: In tank pump
Yes - but you'll need a regulator to reduce the pressure down for your new carb - need a return style regulator like a Mallory 4309.
Old Apr 24, 2011 | 09:22 PM
85T/A350's Avatar
Engine: 350 Vortec
Re: In tank pump
Will I need the regulator if the car was factory carb and im still using a mechanical fuel pump?
Old Apr 24, 2011 | 10:30 PM
Car: 1992 RS
Engine: Carbed 350
Re: In tank pump
No
Old Apr 24, 2011 | 10:55 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: In tank pump
Removing the comp or cutting it off from the motor?
I eliminated cc stuff (carb and dist.) about a year ago. What I ended up having to is install a simple relay for the in tank pump to run when the ignition is turned on. I only had to do this because I got a little carried away when I was thinning out the wiring harness. You'll find that almost everything can go except the fan relay and the pump relay.
Old Apr 25, 2011 | 12:08 AM
85T/A350's Avatar
Engine: 350 Vortec
Re: In tank pump
I plan on completely eliminating the computer.
Old Apr 25, 2011 | 12:37 AM
85T/A350's Avatar
Engine: 350 Vortec
Re: In tank pump
And also, can someone point me to a thread or explain what to do about tcc lock up when you do away with the computer?
chazman
Aug 28, 2018 03:25 PM
theshackle
Mar 5, 2017 06:37 PM
Glowsock
Aug 31, 2015 09:01 PM
Glowsock
Aug 26, 2015 12:28 AM
beachrodder
Aug 25, 2015 08:05 AM
