Motor mounts NOT the source of my problem (WHAT IS???)
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
i took my car out for a spin today after replacing the motor mounts this weekend, and when i get on the gas i still have the same issue...
Symptoms:
-the shifter in my hand lifts up (feels like 3-4in but probably not)
-the back drivers corner of the engine lifts up (ive been driving with the hood off so i can literally see it moving, and its not a subtle shift at all)
-the car feels like its lost torque
What isnt broken:
-the motor mounts (brand new, 3 days old)
-the shells (visually inspected, and would be obvious if broken)
-the bolts going through those two pieces (also inspected and would be obviously broken)
common sence and deductive reasoning leads me to believe that its the transmission mount. (i shouldve thought of this before jumping the gun and spending time and money on the motor mounts but at least theyre done now)
Am i on the right track????
Symptoms:
What isnt broken:
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Motor mounts NOT the source of my problem (WHAT IS???)
ok thanks...
now theres no way a trans mount can be as tough to tackle as those motor mounts right?
im gonna start with the $9.00 mount instead of the entire crossmember
Takes longer to jack the car up and crawl under it, than it does to replace the mount.
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Yep, I agree on the trans mount. There is often a "Clunk" when shifting or when you get on the gas. Be careful, I've heard there are more than one mount for these cars. (I've replaced several and have yet to have this issue, myself.) they say there are more than one height (Thickness). Good luck!
Car: 1989 IROC-Z28 Camaro
Engine: 403 LSX
Transmission: TH400
Axle/Gears: Moser 9" 3.25's
I recommend going with a poly trans mount. Unless you don't mind crawling under your car once a month to replace the broken rubber one.
We'll see how the $9.00 rubber replacement holds up. If not I'll go poly. Not a big deal to crawl under. ( nothing is anymore compared to doing the engine mounts)
I'm thinking there's different sizes cause of the different transmissions that came on these cars.
That may be right, but I have heard of the parts stores having two different sizes for the same trans. I never had a problem with them, though. The rubber one should be just fine unless you run around dumping your clutch and such. For my '90 RS, I had to go solid on the trans mount, but my '86 IROC uses the factory style rubber one. Then again, I've only put around 1,000 miles on it in three years, so who knows. LOL
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
If you get a poly one it will outlast the car. Rubber one will break again in 6 months...
Couldn't stand the poly myself, even though my car isn't a DD. Check the following link for a comparison of ES, Prothane, and OE rubber, which will no doubt last years, depending on how the car is driven:
https://www.thirdgen.org/forums/tran...ison-pics.html
Note the different mounts here (if you have the secondary mount or the oil filled mount, I'd suggest swapping it for a standard, one-piece mount, OE or after market):
https://www.thirdgen.org/forums/hist...ss-member.html
JamesC
JamesC
I think that the up and down movement from my broken old trans mount led to the tork bar mount bolts loosening, so check everything when you are under there.
Omega
Oct 1, 2015 02:20 PM
NBrehm
Aug 5, 2015 07:57 PM
