Timing way off, but idles smooth
Old Apr 27, 2011 | 07:47 AM
djmarch's Avatar
Car: 1989 GTA - Gunmetal grey
Engine: 5.7 ltr.
Axle/Gears: 3:27 9 Bolt Borg Warner
I had my L98 replaced in my GTA by GM performance engines and have had terrible gas mileage ever since. Like around 8 mpg. I disconnected the brown with black striped wire and put my timing light on it and the timing mark on my harmonic balancer is off by 2 inches from the saw tooth towards the drivers side. I tried bringing the mark up to the saw tooth, but the engine bogs down terribly. What could be the problem here ? Could it be GM performance assembled the cam to the crank a tooth off on the gears with the timing chain ? Funny thing is the car idles @ 600 rpms with no miss. There is hesitation though when I open the throttle body fast.
Old Apr 30, 2011 | 07:25 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Timing way off, but idles smooth
Dude, what cam is in that engine? If it is a flat tappet cam in there and you are using the stock distributor then the gears on the distributor/cam are different. From what i remember about this is when i was into the Ford 5.0 motors. The dist. gear on the H.O. was steel , designed to work with roller cams and the flat tappet cam motors used an iron gear. If you mismatch them i don't think you will ever be able to time the car correctly. It will just tear up the gears eventually. So, basically you do not want to run a flat tappet cam with a dist. designed to work with "roller" cams. Check into it.
Old Apr 30, 2011 | 07:27 PM
ninetyone's Avatar
Axle/Gears: 3:42
Also, are you using the stock flexplate and harmonic balancer? They should both match.
Old May 1, 2011 | 07:40 AM
djmarch's Avatar
Engine: 5.7 ltr.
This is a stock L98 complete from GM Performance
Old May 1, 2011 | 09:13 AM
Sounds like you have a damper with a 1:30 timing mark, but a timing cover with a 12:00 timing tab.
Line up the engine to #1 or #6 TDC (same thing, just use whichever is easiest) and mark your damper to match your timing tab.
eightsixseven
Dec 16, 2024 01:50 PM
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
