Harmonic Balancer
Old Apr 28, 2011 | 07:57 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Harmonic Balancer
Can someone help me chose a good ATI balancer that is under 7.5in for this setup.. Thanks..http://www.summitracing.com/parts/ESP-B12111030/
Old Apr 29, 2011 | 10:24 AM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Re: Harmonic Balancer
No one knows of a great balancer for a 383? Or maybe shoot me the right direction. The setup is HSR,xfi292,AFR210, and the above link of course. I guess it does'nt have to be ATI but it needs to be under 7.5in for it to work with my timing cover, and under $500 would be cool.
Old Apr 29, 2011 | 10:45 AM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Go to summit's web site and in the search box type in harmonic balancer. Then use the drill down menu on the left side. What you want is an internal balance unit that is neutral or "0" balance. With that rotating assembly you will also need a neutral or "0" balance flywheel or flexplate. The factory flywheel/flexplates have a weight on them even though the factory motors are internal balance. (except 400 cid)
Old May 1, 2011 | 03:24 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Fluid 7.250
http://www.summitracing.com/search/D...n/?Ns=Rank|Asc
Standard: 7.074
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
