What is the
Old Apr 30, 2011 | 01:37 PM
native1031's Avatar
What is the
Pit arm? And where is it located exactly is it located? Between the shaft and gear/box? or before it?
Old Apr 30, 2011 | 02:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: What is the
the pitman arm is the arm connected directly to the splined output shaft of the steering box. It is a non-wear part and only ever has to be replaced if its damaged somehow.
Old Apr 30, 2011 | 02:56 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: What is the
That search thang again .
https://www.thirdgen.org/forums/susp...ion-101-a.html
JamesC
Old Apr 30, 2011 | 03:06 PM
native1031's Avatar
Re: What is the
JamesC thanks again haha. So I bought the rebuild kit for just the power steering box, snap ring pliers, and I didnt have enough for the pit arm remover(Didnt know it was 30 somethin bucks).
Is there anything im missing? Do I need a new rag joint, lock nuts and bolts. Or can I reuse them?
the leak is coming out from in between the steering box and the shaft
UPDATE: Did some searching and it appears the rag joint is in between the shaft and the steering box. Should I replace parts since this it is in the area of the leak and since im down there
Old Apr 30, 2011 | 04:39 PM
native1031's Avatar
Re: What is the
Is everything here for the rebuild? Do I have all tools required for removal and instalation other then the basic tools
