86 Z28 HELP!!!!!!
Old Apr 30, 2011 | 09:27 PM
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
86 Z28 HELP!!!!!!
Okay so I thought the problem was fixed but now I know better being that my 86 Z28 is a paperweight currently!!!! I was headed home when all of a sudden the entire driver side of my muffler blew off the car died and now will not start she wants to turn over but can't seem to so any suggestions of what to do would be appreciated!!!!! I just got her out of the shop a week ago for a timing issue and to me she seems to be acting the same as before!!!!! She was backfiring into the MAFS just before I pulled over and she destroyed herself!!!!!
Old Apr 30, 2011 | 09:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 86 Z28 HELP!!!!!!
Please only post once.
Old Apr 30, 2011 | 09:59 PM
Engine: 5.0 305 TPI
I would appreciate help not sarcasm from the people here that know more about the issue at hand if i posted more than once then i am having computer problems as well i'm sorry any help??????
Old Apr 30, 2011 | 11:37 PM
WESTOF7's Avatar
More detailed explanation please. Did you have oil pressure?
Old May 1, 2011 | 01:39 AM
Engine: 5.0 305 TPI
up until she died i had oil pressure and i do now but still will not start
Old May 1, 2011 | 02:16 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Check spark, fuel pressure and injector pulse. From the sound of things, your ignition dropped spark for several revolutions and your exhaust filled up with raw fuel, then spark came back and ignited the raw fuel. It sort of turns your exhaust into a pipe bomb. Check for an issue with your ignition system. I bet you will find you have no spark. Or that you have poor an intermittent connection at your ignition coil. Read the HEI description and follow the diagnosis procedures outlined towards the bottom of the page in my "wiring diagrams" thread on the Electronics forum.
If you find no trouble with your ignition, suspect lost cam timing as in broken timing chain.
starliner
Feb 9, 2016 08:18 PM
blackz281le
Jan 11, 2016 07:51 AM
David Frans
Oct 31, 2015 08:12 PM
Night rider327
Oct 9, 2015 09:25 AM
z28joe2
Sep 28, 2015 05:54 PM
