350 cam suggestions?
Old May 1, 2011 | 10:21 AM
Ambition's Avatar
I have a 88 tran am with a tbi 350. It is flat cam engine but does have vortec heads. I'm going carbd with edelbrock dual plane or rpm performer not sure yet and a 650. Basically want a somewhat aggressive cam kit that's not gonna be too hard on valve terrain, lookin for some suggestions. Also suggestions on intake and carb? Thanks alot
Old May 1, 2011 | 11:45 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: 350 cam suggestions?
comp cams xe262 is what ive run for a while and been happy with it. if i were to do it over again id go with a roller instead of a flat tappet. more expensive though...
Old May 1, 2011 | 01:24 PM
TNT_Z28's Avatar
Originally Posted by Ambition
I'm going carbd with edelbrock dual plane or rpm performer not sure yet and a 650. Also suggestions on intake and carb? Thanks alot
a duel plane intake is what you want. a performer rpm is a duel plane manifold.
i had an edelbrock manifold crack on me at the coolent passage. that was probably an isolated insodent, but nevertheless, the only thing edelbrock on my car now is a sticker
650 sounds good for size. shouldnt need any bigger for a 350
Old May 1, 2011 | 07:52 PM
Ambition's Avatar
Ok thanks alot. Gonna call comp cams tomorrow I want to get at leaste 300hp out of it so is there any other suggestions while the motor will be torn apart. I'm also ordering a msd HEI distributor
Old May 1, 2011 | 08:07 PM
TNT_Z28's Avatar
your vortec heads are a positive
if youve got the money, some machining to the heads would be worth it while they are off the block.
theshackle
Sep 17, 2020 08:26 AM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
theshackle
Aug 22, 2015 06:52 PM
