starter problem
Old May 3, 2011 | 05:34 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
starter problem
So my old starter has been on its last leg like my battery. So last weekend I decided to put a new battery and starter in. When I did this the starter I put in wouldn't even turn over.I got another starter and still nothing.battery is fine everything is hooked up just how its supposed to be.any ideas guys
Old May 6, 2011 | 04:24 PM
Scee's Avatar
Re: starter problem
Im going through the same problem almost. Except i swapped engines and now mine wont crank. Check the crk fuse under your dash. Makr sure the starters bolted to the engine correctly because it only grounds out when its tight against the block.
Old May 6, 2011 | 05:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: starter problem
Obviously not.
All wires going to the starter connect to the larger starter terminal, along with the pos battery cable. Only the purple wire goes to the smaller terminal, all by itself. Did you connect it like that?
Old May 15, 2011 | 01:22 PM
dunkirk's Avatar
Re: starter problem
Make sure that the Neutral switch isn't creating the problem, I rewired mine because the starter failed to turn over because the connection are so bad. Had to eliminate it, I put in a starter button and eliminated the switch all together
Old May 19, 2011 | 11:40 AM
jaysfs's Avatar
Transmission: t56
Re: starter problem
I have put in numerous starters in our always wonderful cars.I do know where wires go. But I'm not getting any juice to the purple wire. Going to track it down tonight.
Old May 19, 2011 | 07:06 PM
Car: 1992 RS
Engine: Carbed 350
Re: starter problem
This might help: http://www.austinthirdgen.org/index.php?pid=38
Old May 19, 2011 | 08:15 PM
jaysfs's Avatar
Transmission: t56
Re: starter problem
Thanks guys I got it started.I need a new starter enable relay.I hot wired it there. And that is a very useful page you put up.I will try to post pic of her when she gets out of he both of work in the next week or so
Spyder_TheGamer
Dec 25, 2015 05:07 PM
5spdcamaro
Aug 28, 2015 02:12 AM
92camaroJoe
Aug 13, 2015 06:07 AM
milk
Aug 10, 2015 06:26 PM
