I'm back fellas...gotta question
Okay so I posted on here awhile back about my car failing smog because of a leak somewhere near the gas lines near the gas tank. Well I finally crawled under there and this is what I saw. I noticed the other day I was reving it up for a good 4-5 mins too see if there was actually a leak because everytime I do rev it the fumes in the car get stronger. And there looked like there was a puddle around the area of the fuel lines where the gas tank is.
Re: I'm back fellas...gotta question
Ya I'm pretty sure that hose that is disconnected is the air hose or whatever u call it. It's not suppose to be connected to another hose or anything
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Looks like the mud dawbers have filled it with spiders and dirt.
There should be something connected to it - I think it's for the check valve vent. 3 lines run to front of car, 4th is a vent that acts like a check valve - it's white (minus road grime), round about 1.5 inches diameter.
So the one that is sorta orange looking is suppose to have some kinda check valve on it than?
:update:
After lookin around I realized there's no check valve present would this be causing fumes to get into the car?
:update:
91 rally sport
22
Apr 5, 2016 05:06 PM
