spark plug problems
Old May 10, 2011 | 08:15 PM
Racca116's Avatar
Car: '85 Camaro Z28
Engine: 355 carburated
Transmission: TKO600
Axle/Gears: GTA rear, 3.73 posi, hotchkiss
spark plug problems
so im running a 355 with a cam and all thaat good stuff. problem is, i have an MSD ignition and 2 of my plugs are arching to the block. the plugs were replaced last summer, but i didnt drive it from august till this month. is the MSD too strong for the regular ole stock delco plugs or are they more likely defects. in the case of the first one or in general, are there better hi performace plugs i should run to take the extra voltage?
Old May 10, 2011 | 08:35 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: spark plug problems
Plug boots may be split, or may be burned enough to let the spark jump.
Old May 10, 2011 | 08:41 PM
Racca116's Avatar
Car: '85 Camaro Z28
wires are brand new MSDs replaced with the plugs tho
Old May 10, 2011 | 08:48 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
MSD isnt too strong. check connections and boots as stated above
dont fall for gimmicks. (such as the e3 $6.00 a plug), plugs are plugs. only difference is some burn hotter than others.
Old May 10, 2011 | 09:08 PM
Racca116's Avatar
Car: '85 Camaro Z28
ill do that, also, a buddy of mine runs the same ignition set up on his chevelle with a 383, im runnin r45 plugs i belive, he said go with r43s which are colder i guess. would the fact that my plugs arent "cold" enough cause this problem?
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Feb 28, 2016 03:33 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
