Dash & brake lights wont turn on
Old May 14, 2011 | 10:43 PM
DiligentWaffles's Avatar
Car: 1983 Camaro
Engine: 2.8L V6
Transmission: manual 5-speed
hey got a 83 camaro and I just barely brought it back to life but what i noticed is that my dash wont light up and the brake lights only light up when I press the brakes....and yes I do turn on the headlights...please help
Old May 14, 2011 | 10:52 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Dash & brake lights wont turn on
tail lights bulbs are bad or a bad fuse. [wiring maybe]
old GM trick, your dash lights go out so you know your tail lights aren't working right.
Old May 14, 2011 | 10:55 PM
Car: 1983 Camaro
Engine: 2.8L V6
ok so i just checked the fuses n im missing a "20" thats labeled in the slot of "courtesy WDO"? does that have anything to do with it? i got a manual but it doesnt cover this topic
Old May 15, 2011 | 04:32 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Put a new fuse in. Does the cig lighter work?
Old May 16, 2011 | 02:03 AM
Car: 1983 Camaro
Engine: 2.8L V6
uhm i misread the fuse label it was the tail light fuse that burnt out... that courtesy WDO has an arrow pointing to another fuse but that one is ok..so now im looking for an exposed wire or sumthing that causes the fuse to pop
Old May 16, 2011 | 08:18 AM
I believe the cig lighter is on that fuse also. Both of my camaros the cig lighter didn't pop out, and blew the fuse. I gutted the lighter and put it back in.
Old May 16, 2011 | 08:27 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
You may also have a shorted bulb.
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
tnrednneck
Aug 13, 2015 08:57 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
