Rocker arm nut
Old May 19, 2011 | 02:36 PM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
Rocker arm nut
Today I tried to mock up one of the rocker arms to check a few things on an engine that is under rebuild.
Started to put the nut of the rocker on the stud by hand and it was going on it smoothly. When the stud reached the top of the nut inside it got hard to turn. By hard I mean that I can't even turn it further by hand. With a wrench I can continue turning it.
My question would be whether this is normal and designed this way to keep the rocker nut in place while the engine is running or something is wrong here?
The rocker studs were changed on the cylinder heads to ARP screw-in studs.
Old May 19, 2011 | 06:48 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Rocker arm nut
It's normal. The tops of the nuts are oval shaped rather than round - this keeps them from loosening up on their own.
Nylon locking nuts won't work - the nylon will melt under the heat.
Locking washers won't work - no real room for them, and nothing really for them to catch on, and the valve train force will take them out anyway.
Thus, these nuts are squished into an oval at the tops, so that they can't back out on their own.
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
