Cylinder head question
Old May 20, 2011 | 12:26 AM
macmatt's Avatar
Car: 1991 Pontiac Firebird
Engine: 305 TBI
I have a 91 firebird 305 tbi. Anyone know what cc the cylinder heads are on this engine? Looking into getting new ones (performance) and wanted to get the right ones. Thanks
Old May 20, 2011 | 07:32 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: Cylinder head question
I believe stock 305 heads are 58cc. You could get a set of vortec heads, which are 64cc and have them milled to retain compression. You'd need a different intake manifold for vortec's though.
My advice would be to build a 350 for performance on an engine stand while you can still drive your car as is daily.
Old May 20, 2011 | 09:50 AM
macmatt's Avatar
Engine: 305 TBI
Yeah that's kind of what I was beginning to think. Every which way i've looked at it it was about the same price or a bit cheaper to build a 350 for it. I've thought about doing that using the existing tbi setup. But also thought a carburetor would be easier. Still looking into it. My 305 is running smooth right now so I have some time to figure it out.
Old May 20, 2011 | 11:04 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I wouldn't waste time on heads purchase for a 305, unless you get a pair for under $500 - then we're still talking custom chip tuning unless you swap to carb. Either do a 350 TBI swap, or carb a 350 and swap it - the 305 just isn't worth the time/money/trouble to me.
Old May 20, 2011 | 11:28 PM
macmatt's Avatar
Engine: 305 TBI
that's prety much what I've been leaning towards. When I looked up the price of a stock replacement 305 from autozone and then a stock 350 (that would have come out of a car like mine only a t/a) the 350 was actually cheaper. If the reman company built the 350 to spec then it would have 245hp out of the crate. Compared to the 170hp of the 305.
fasteddi
Sep 2, 2015 10:29 AM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
