broken block use or bin
Old May 21, 2011 | 02:47 AM
austleadfoot's Avatar
Car: 86 ta firebird
Axle/Gears: borg 277:1
hi ,bought a 350 4bolt roller cam clean std bore but when i got home found the bottom bolt hole on the block broken off,where the bell housing bolts on ,can i use the engine ? or do i need to bin it,any advise
Old May 21, 2011 | 08:08 AM
Guest
Guest
Posts: n/a
Re: broken block use or bin
A pic would help, it might not be junk. If you can't post a pic, then find an honest engine machinist to look at it.
Old May 21, 2011 | 08:14 AM
Car: 86 ta firebird
i will try to get a pic tomorow . its the bolt hole on the opisit side to the oil filter,that you bolt the bell housing to
Old May 21, 2011 | 12:28 PM
Guest
Guest
Posts: n/a
Depending on what happened, it may be difficult to attach the starter. There is a company making a bracket for the early blocks, like 1955-1956, that might prove useful.
As for attaching the transmission, having to leave out 1 bolt is not a big problem.
Old May 21, 2011 | 07:10 PM
Car: 86 ta firebird
i dont know how to add a photo here . i have pics in my home page i think
skeltor
Feb 2, 2016 10:37 AM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
ctoledo0834
Sep 18, 2015 04:16 PM
RyanJB
Sep 14, 2015 03:39 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
