Question about head bolt torque
Old May 22, 2011 | 09:18 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Axle/Gears: 4th gen rear with 3.42
I got Trick Flow's head bolt kit. The instructions that came with the bolts say to torque the bolts to 80 ft/lbs if you are using 30W oil to lube them. Does that seem excessive to anyone else? The heads are AFR 180's and I don't want to ruin them.
Old May 22, 2011 | 10:29 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Re: Question about head bolt torque
If that's what it calls for, no. I believe for cast iron heads, Haynes calls for 60 ft-lbs. Thats what I've done in the past, but I wouldn't wonder from spec.
Just make sure you torque them in sequence, in about 20 ft-lbs. Increments.
Old May 22, 2011 | 11:55 PM
spurgeon76's Avatar
Car: 1989 IROC-Z
Yeah I torqued them first to 40 (per the sheet from trick flow) then to 60 and then to 80.
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355tpipickup
Aug 25, 2015 12:54 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
