cut wires
Old May 22, 2011 | 09:31 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
cut wires
i had the motor out to put in a different one and while it was out i got rid of some of the wiring. I only cut wires that did not go to anything. But now to roll the windows up i hit down and to roll them down i hit up. And nothing inside the car works now either. Also fuel pump doesnt kick on. What did i do? as i didnt cut any wire that was connected on both ends. What wires have to run from one side to the other?
Its a 1992 firebird thats carb'd
Old May 23, 2011 | 12:07 PM
BahN's Avatar
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
Re: cut wires
Check to make sure you didn't accidentally bump/pull the C100 connector out a little. This connector provides power to the interior and sensor data to the dash. The C100 is located next to the brake booster:
Old May 23, 2011 | 03:32 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: cut wires
checked that its tight. Do i need the computer in the car at all if its carburated? And my dash lights work but my head lights dont come up. It turns over but none of my auto meter gauges work. Also the defroster light is stuck on. But if i dont need the computer i will take it out and eliminate more wiring. This is gonna be a drag/street car so i just need lights and blinkers none of the gauges work anyways.
Old May 23, 2011 | 04:05 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: cut wires
I AM A DUMBASS lets just get that out there both my cables are black and i had them hooked up backwards. Now how much **** did i break? my gauges work now but the radio does not and the fuel pump niether but the pump is an easy fix.
Old May 23, 2011 | 04:07 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: cut wires
NEVER, EVER, EVER, CUT A WIRE!!! Just because it doesn't appear to do anything doesn't mean it won't affect something.
Old May 23, 2011 | 04:15 PM
hartman's Avatar
Car: 1992 firebird
Engine: SBC 350
Transmission: TH350
Re: cut wires
i only cut wires that went to nothing. They were already cut by the PO and i just shortened them and got rid of them.
Old May 23, 2011 | 04:51 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: cut wires
Make sure all of your grounds are hooked up.
Jeremys87
Jul 14, 2022 09:08 PM
Caspar
Jun 19, 2016 11:19 PM
mhatfield 14
Aug 15, 2015 10:47 AM
apie2546
Aug 8, 2015 07:12 AM
