Code 32+ loss of OD + overheating =?
Old May 26, 2011 | 08:13 AM
raycer's Avatar
Car: 86 IROC
86 IROC 305 TPI 700r4
Ok, I noticed that my car was taking longer to shift and seemed sluggish. Then on the way home it wouldn't shift into OD. A few miles from home it set of code 32 (EGR) and when I got home the car had over heated a bit and fluid came of from arounf the rad cap. It's cooled down quickly so I guess it wasn't that hot and not for too long.
So is the over heating and EGR and no OD related?
I was thinking the no OD might be that the car went into some sort of limp mode, but it didn't trip the engine light till like 10 minutes later.
Old May 26, 2011 | 07:33 PM
raycer's Avatar
Car: 86 IROC
Re: Code 32+ loss of OD + overheating =?
Cleared the code and added coolant. Started up the car with the radiator cap off and it didn't shoot fluid out like there was too much pressure. Put on a new rad cap since the old one was on there when I got the car last year. Turned on the car and warmed it up, and revved it a few times to get it hotter. Used an infrared temp gun and no part of the engine went over 175* at any time. Here's something I noticed though. The over flow is fuller than normal and even with the new cap, some antifreeze is dribbling out from under it, but nothing boiled over.
Old May 26, 2011 | 08:53 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Is your OD back? code 32 is egr related. Should not effect performance. I have driven around for miles with it til i got my new chip burned. How hot did it get?
Old May 27, 2011 | 05:06 PM
raycer's Avatar
Car: 86 IROC
I am not sure how hot it got since my gauge doesn't work. I'm not even sure it got that hot since my reasoning for believing it was hot was the AF spilling out of the cap, but it seems to do that anyway. Like I wrote above though, when I went to test it with a temp gun, it never went over 175 ( I have a 180 stat)
Thanks for the reply, I can use all the help I can
Old May 27, 2011 | 06:30 PM
ninetyone's Avatar
Axle/Gears: 3:42
So you still have no OD?
Old May 27, 2011 | 08:26 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Are you lacking overdrive or just the lockup on the torque converter?
Old May 27, 2011 | 09:31 PM
raycer's Avatar
Car: 86 IROC
I wasn't able to drive it today to test for OD. I mean actually OD, as in it only would shift up to 3rd gear.
Falcon50
Aug 22, 2020 03:26 PM
RedLeader289
May 28, 2019 01:47 PM
racereese
Oct 3, 2015 03:46 PM
3.8TransAM
Sep 27, 2015 08:37 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
