help built 350 weak spark
Old May 26, 2011 | 11:01 PM
snowboardgod869's Avatar
Car: 1991 RS Camaro
Axle/Gears: 9 bolt 3.27
i have a built 350 with a cam an a hei distributor on it and im getting weak spark for some reason she wants to fire but once you get her started she just falls on her face and has a hard time just getting started its a brand new motor zero miles its in my 91 camaro im not sure what the problem is i rigged the distributor up to make sure it worked before i put it in the car its used and i got a nice blue spark on a spark tester but she still doesnt want to fire
Old Jun 16, 2011 | 08:16 PM
hitest's Avatar
Re: help built 350 weak spark
Do you get some sort of ignition spark from your HEI distributor? You could either have a problem with 12Volt supply saturating the coil or a problem with the condenser. Do you have a CDI box firing the coil? If you dont want to invest in an MSD box and you do have a spark except it is not strong enough then you could try a HEI distributor spark amplification system.
camaro11j
Sep 19, 2018 08:49 AM
LittleFranks
Sep 17, 2015 12:22 PM
Eric-86sc
Aug 24, 2015 09:01 PM
neekolzun
Aug 24, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
