low fuel pressure
Old Jun 2, 2011 | 11:26 AM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
low fuel pressure
lastnight my car died again. it does not keep 43psi if fuel pressure after i drive it around for a while.
after it died i popped to hood to look at my fuel pressure guage and it reads 10psi
-i turn key forward to prime pump it, listen for relay and fuel pump. i can hear both
-step out side and look under hood... still 10psi
-i crank starter for a few seconds and it fires run out to fuel guage, it reads 30psi and starting to drop
-if i leave the car overnight ill start it up and 43psi
i cant take it to a shop because it will run fine so its no good to them unless it shows its face right there.
is it a bad pump?
ive replaced:
fuel pump a 7000kms ago with a walbro 255
fuel filter
relay
kirban adjustible regulator 2000kms ago
im all out of ideas
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
