Is it time for new injectors?
Old Jun 4, 2011 | 03:46 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I thought I had a leaking injector so I pulled the rail and non of them are leaking. I think my pump is bleeding off but Im not going to worry about it.
Anyway, I had the rail over a couple of buckets and used the battery to fire off each inector with about 30 PSI of fuel pressure. Each one went off like a laser beam. No nice conical atomized flow. This was a dead straight fuel stream. Would I benefit from an injector upgrade? If so, which do you reccomend?
Car is not stock. It's bored .020. .202 intake valves and 194 exhaust. Headers, flowmaster, Cam is more than stock but not radical. Cold air intake. Plenum hogged out. Accel ignition, the usual stuff.
Old Jun 5, 2011 | 10:33 AM
southbay08's Avatar
Re: Is it time for new injectors?
try running the engine for a minute or two, then pull the plugs, if you have a wet cylinder you have a leaky injector.
midge54
Dec 27, 2019 04:14 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
justin57
Aug 20, 2015 07:05 PM
ezobens
Aug 19, 2015 10:29 PM
Bryan F
Aug 18, 2015 02:28 PM
