fitting gen3 vortec head on a old 383
Old Jun 9, 2011 | 12:42 PM
etellier's Avatar
Car: Trans am 82
Engine: 350 4brl on his way to tpi
Transmission: 700r4 with b&m Shift kit
Axle/Gears: 3.43
Hey folks, i was wondering if a generation 3 LQ9 6.0 aluminium head would fit on a 383 that i am rebuilding, i know the intake has to be replaced, but would it fit there, also, would the headers still fit ? anything else i should look into as per fitting issues?
6.0 ESCALADE 6.0liter LQ9 Heads
2001+ 6.0L Truck
Material: Aluminum
Combustion Chamber Volume: 71.06cc
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
thx folks
Eric
Old Jun 9, 2011 | 01:28 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Re: fitting gen3 vortec head on a old 383
Won't work. Different head bolt location .
Old Jun 9, 2011 | 01:40 PM
etellier's Avatar
Car: Trans am 82
Axle/Gears: 3.43
ok thank you for the info!
Old Jun 10, 2011 | 03:07 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Bolt pattern has nothing to do with it
All together completely different engines.
The only thing that interchanges between GEN 1 and 2 engines and GEN III (LS ) engines is the Chevy badge
Old Jun 10, 2011 | 08:32 AM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
word products produced a modified gen 1 small block that will accept gen 3 heads...
http://www.lsxtv.com/forum/world-pro...-sbc-1235.html
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bamaboy0323
Sep 3, 2015 06:07 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
