power steering question
Car: 1982 Z28
Engine: 383
Transmission: TCI TH350
Axle/Gears: 3.23 Posi
Has anyone swapped out their saginaw power steering unit with a GM type II? I am getting real tired of the impossible to get to bolts on the aftermarket power steering brackets and I am considering swapping to a type II with remote reservoir.
Will the lines from the saginaw work or will I need new ones? The lines summit sells says for up to 1978 so I am figuring that after 1978 it's metric or something.
It's frustrating to have to remove the pulley on the power steering pump to get to some of the mounting bolts.
Thanks for any advice.
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
