91 z donut problem...
i have a 91 z l98. i used to be able to bust donuts like nothing back not that long ago....then i bought some new tires and i i havent done any, so i wont waste my 245s(expensive tire)... it still burns tires like crazy just by taking off. i tried to do a donut yesterday and it feels like one tire locks.... and does not want to do them.........what could be the problem... i did the gear oil change... but did not add posi additive.... could this be the problem?? some liquid??? or my rear end is just old and abused????
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 91 z donut problem...
Do a burnout in a straight line and see if you leave 2 black stripes. If you dont your posi is done.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Donuts = child's play. Why put your car through this abuse? Only serves to lessen the life of the tranny, rear gears, posi unit, etc. Do you not like the car?
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Man lighten up. If you can't play with your car when you feel like it what's the point of the car? Or life. We all play (I hope) in different ways. It's America after all. Excuse me while I get off your lawn.
Engine: 4++,350 & 305 CIs
I myself am a fan of doughnuts, burnouts and general silly-ness with a car. Its y i built mine!.. good times.. its also good stress relief!
All done in place for it of course
yes i love my car. i just want to know why all of a sudden it wont do it. im not going to go bust donuts , i just wana know that if it comes down to it , my car will be ready to do them.
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
You should also do some killer "neutral drops" too for added fun before doing donuts ! Tach your motor up to 4000 rpms or so then slam it into drive !
Your friends will be so impressed.................
Think of all that impressive tire smoke !
negative...thats asking to destroy my trans and engine....
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
I just had to get new tires too. Can someone figure out why this happens?
The spring in the dif has become weak. Either your clutches/cones spring are worn and need replaced or shimmed to increase the torque capacity of the diff. I over shim mine a tad. You dont want to go to crazy with your shimming because it'll wear your clutches/cones waaay to fast.
A GM service manual will answer these questions and many more you will have.
thats just like what drag racers do but with a manual trans.. and slicks! guys/gals used to do this back in the day b4 high stall converters.. yup its all hard on stuff ! I do crazy stuff to my car all the time.. I giggle like a little school girl when I break somthing.. Its fun for me to drive break and fix it because I can!
Car: '82 Z28
Donuts and burnouts are fun, ***** the haters who have a stick up their ****
Breazlan
Sep 25, 2015 11:20 AM
