High Hydrocarbons on test
Old Jun 11, 2011 | 07:32 PM
Megalo's Avatar
Hi, i got a 78 camaro with a 350 in it. It has high hydrocarbons on an efficiency test. One of the cylinders makes a slight knocking sound untill I warm up the car, is this a weak lifter? It can also take a while to startup if it has been sitting a while. I got all the spark plugs and wires changed, sounds slightly better but not a significant difference. I have not had the car long, it was in storage for many years before I got it. Any suggestions on what I should look at next is appreciated.
Old Jun 11, 2011 | 07:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: High Hydrocarbons on test
Try a compression test.
Old Jun 11, 2011 | 08:34 PM
90 camaro cj's Avatar
Car: 1990 camaro RS
Engine: 305 TBI
is the timing right? Hydro carbons are from unburned fuel going out the exhaust, id say lean the carb and check the timing, should clean it up
Old Jun 11, 2011 | 08:40 PM
Gabaloo's Avatar
does that year have a cat converter? my 92 had the same problem passing emmisions. you could try driving it around getting the cat real hot and then getting directly in for a test. when it sits waiting in line, it cools off and causes a high HC count.
i put in a new CC and passed with all zeros
Old Jun 11, 2011 | 08:49 PM
Car: 1990 camaro RS
Engine: 305 TBI
That would have a cat but they never go bad. They are really big and I've never seen one go bad in those cars
Old Jun 11, 2011 | 09:28 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I would do a manual compression test to the engine. If the noise is a knocking noise and goes away when it warms up, I would say thats a piston knock. Are you hearing the noise from the top or the bottom of the motor? A lifter would make a ticking sound and would usually get louder as the engine warms up if its not pumping up. Hard start and high hydrocarbons could mean that the carb could need rebuilding or adjusted if the car has been sitting for a long time.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
eustodp
Sep 20, 2015 05:09 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
