can't make donuts, posi slipping HELP!
Old Aug 11, 2001 | 01:58 PM
pontiac's Avatar
is there anything to do for slipping posi? symptoms are: if i turn and hit the floor, only one wheel is spinning. only way to make decent donuts is to burn some rubber with brake and when both wheels are smoking, release the brake. but it would be more nice to just do donuts with gas pedal anything i can do to fix posi or to make it more tight?
-P (just wondering)
Pontiac Trans Am GTA'89
CC1 GW6 G80 JG1 L98 MXO N64 WS6 822
mods: firebird '89 four spoke steering wheel and i'm still not running low 13's yet!
Old Aug 11, 2001 | 06:22 PM
Jay 727's Avatar
I don't know why you want to do donuts but anyway you need to remove the cover and see if you have a gov loc rear, get a new diff if you do, see if its a cone type posi, if it is get a new diff, if its a clutch type posi with a Z shaped spring get a new diff, if its a clutch type posi with coil type springs rebuild it. Go with an auburn for a low priced cone type diff, or get an Eaton for a high dollar bullet proof differential.
Old Aug 12, 2001 | 06:02 AM
pontiac's Avatar
i think '89 GTA have australian made BW rear. not so easy or cheap to rebuild? would any type of gear oil help with slipping?
-P
Old Aug 12, 2001 | 07:48 AM
ede's Avatar
ede
spinning the tires while turning is about the best way to trash a posi.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
novaderrik
Aug 10, 2015 12:44 PM
