T5 rebuild ?'s Pics inside.
Old Aug 11, 2001 | 07:59 PM
bhaas's Avatar
Pics aren't working. Sorry.
I have a 1984 T5 NWC and I bought the rebuild kit and video from Hanlon, but the counter shaft on mine doesn't have the cover with 4 bolts like the one in the video. It looks to me to be totally pressed in. So do I just press the whole shaft out, bearings and all at once? Or is there some other way to do it?
Thanks. This is the only part holding me up. The rest is done. Also what should the end play be on it? I have about 30 thousandths of end play. Seems a bit much. Thanks.
Brad...
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Soon to be T5 YES!!!
[This message has been edited by bhaas (edited August 11, 2001).]
[This message has been edited by bhaas (edited August 12, 2001).]
Old Aug 11, 2001 | 08:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Can't see the pics...
If it's a non-"WC" trans, then the easiest way to get the countershaft out, is to press it out from the front, bearings and all as a unit. Then when you go to put it back together, put the gear in first; then the spacer washer for the rear bearing, and the thrust washer at the front; then the rear bearing; then the front bearing with some kind of sealer on its outer edge. I haven't seen the video but I'm gong to assume from you description that it shows a "WC" trans. .030" of endplay in the countergear is reasonable.
ICON Motorsports
Old Aug 11, 2001 | 08:44 PM
bhaas's Avatar
Thanks. I'm gonna go press it out now. Right on.
Brad...
Old Aug 11, 2001 | 08:50 PM
bhaas's Avatar
Pics are working now. But for some reason I see people getting a 404 error. Let me know if anyone else can see them. Had to download another http server.
Thanks.
Old Aug 11, 2001 | 09:20 PM
bhaas's Avatar
It seems like any one with a 24.10.xx.xx IP address isn't getting these pics. Hmmmm. Gonna try another server.
Brad...
Old Aug 12, 2001 | 08:06 AM
bhaas's Avatar
Damn. I cracked the housing around the front bearing trying to push it out. F&*K!!! Now I need another housing.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
FormulasOnly
Sep 10, 2015 09:07 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
