Fuel feed and return lines
Old Jun 11, 2011 | 10:46 PM
Dwax13's Avatar
Car: 1986 Trans Am
Engine: Carbed 355
Transmission: Th700R4
Axle/Gears: 3.73 Posi
Ok i have in this picture the fuel feed and return line i know the feed line is bigger than the return one but my question is what size thread with a barbed end do i need for each one i know the return line is 5/16 and the feed is 3/8 barbed end what about the end that attaches to the stock lines coming from the car?
Old Jun 12, 2011 | 09:13 AM
Dwax13's Avatar
Car: 1986 Trans Am
Engine: Carbed 355
Re: Fuel feed and return lines
anyone know?
Old Jun 12, 2011 | 11:35 AM
Vader's Avatar
Sorry. I looked through several records from TPI conversions I have done and i did not record the Dorman part numbers. My invoices only show that it was a Dorman part from Autozone.
Old Jun 12, 2011 | 12:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I simply got metric to barb brass fittings at local hardware store in the plumbing section (think it was an ACE Hardware).
Old Jun 12, 2011 | 04:22 PM
Dwax13's Avatar
Car: 1986 Trans Am
Engine: Carbed 355
ok there metric that explains why i couldnt figure out the size does anyone know what metric size fitting screws into them?
Old Jun 12, 2011 | 05:13 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
what is it exactly that you're doing? is this a carb conversion and u plan on running rubber from the barb? Last one I did I got fittings to attach the lines to my 3 port regulator and ran the new feed line from the regulator to the carb...
Old Jun 12, 2011 | 05:23 PM
Dwax13's Avatar
Car: 1986 Trans Am
Engine: Carbed 355
yes i am converting from tpi to carb and yea i want to run rubber hose from the barb like you said sorry for not clarifying that earlier.
Old Jun 12, 2011 | 05:48 PM
ex-x-fire's Avatar
They are called saginaw fittings in 16mm & 14mm X 1.5(?).
Old Jun 12, 2011 | 08:24 PM
Dwax13's Avatar
Car: 1986 Trans Am
Engine: Carbed 355
ok thank you i found them on summit
Old Jun 14, 2011 | 05:41 PM
galletti's Avatar
Car: 1988 IROC Convertible
What he said. In the TPI fuel rail mod thread the mention 16 and 14mm x 1.5. I'm still a little confused because one person mentioned 1.5 and another 1.5 o-ring. Does anyone know if the lines have the o-ring fitting? Thanks.
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
wayshegoes
Aug 17, 2015 12:00 PM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
